深度家族又添加了一个新成员,深度软件包管理器V1.0正式发布啦!
深度软件包管理器是一款deb包管理工具,方便用户安装商店以外的自定义应用。界面简单易用,支持批量安装、版本信息识别和依赖自动补全等功能,只要您获取正确的deb包就能快速地安装在深度操作系统上。
界面简洁,一键安装
界面设计简洁,非常直观的显示软件包名称、版本号、描述等信息,只需点击安装按钮即可完成。
状态检测,智能提醒
后台自动检测软件包当前安装状态,在界面上面直接显示当前软件包是否已安装、重新安装、卸载已安装、是否满足依赖等提示。
批量安装,列表展示
支持批量安装软件包,以列表的形式的展示,后台自动排队安装,同时自动检测依赖关系给出安装进度和状态。
依赖关系,自动补全
安装过程中,如果缺少依赖包,后台仓库自动补全依赖关系,匹配满足的依赖包并自动安装。
大家可以通过深度商店搜索下载获取深度软件包管理器V1.0。
Can't install it via deepin store, it's a real pain! Doesn't work, been waiting for several minutes.
What's the package name I can't find it? Gonna go cli.
sudo apt-get install deepin-deb-installer
Unable to locate package deepin-deb-installer
jingle@jingle:~$ apt-cache policy deepin-deb-installer
deepin-deb-installer:
无法定位软件包
I was able to install using sudo aptitude install deepin-deb-installer and it worked.
am able to search and find it as "package manager" from computer.
great Job guys!!!!
太厉害啦,用户福音
When you can see this news in other languages ?
А что ТЫ сделал, чтобы задавать подобные вопросы? Чухай на свой сайт и не пизди здесь!
Sorry? You're crazy? Do not answer, if not to the case
怎么查看包含的文件列表
你是指的依赖关系列表?
无法安装,什么情况?
可以吗?
细节隐藏太多了了 Gdebi可以直接查看包里面的control细节 脚本也能看到
普通用户不关注这个,哈哈
怎么重装应用商店?
sudo apt-get install --reinstall deepin-appstore
Top D+!!! Consegui instalar normalmente pela Deepin Store e testei instalando pacotes .deb .
Hey Guys! for the 2nd time my OS is broaken. This time when I tryied to install teamviewr and the deepin package manager unistall a lot of packages and the system (production) is down, and unfortunately I can restore.
Pls help to patch instead of reinstall.
([email protected])
teamviewer ?
Yes, curiously... I choosed install the package, the "deepin package manager" uninstall some packages and the system crashs. Unfortunately I cant enter again and lost te current instalation bc the restore method doenst work. I recorded a video about it. And aditionaly I have others issues and suggestions on the feedback tool.
Hello, please give me your address and the name of your package.
Hello jingle!
Pls download the file v12.0.76279 (deb 32-Bit / 64-Bit Multiarch) at
https://www.teamviewer.com/pt/download/linux
I choosed install by "deepin package manager" and this issue happens.
If you wanna talk to me, send me messagens to [email protected]
Tks for your attention.
I will testing it
什么时候连tar.gz包和rpm包都能用深度软件安装包安装就好了
tar.gz 部分是源码包 部分是二进制包 踪迹编译或直接运行
rpm 可以转 sudo apt-get install alien
Deepin пополняется реально полезным функционалом.
В этой системе есть реально всё что надо. Терминал я вообще практически не использую.
Идеальная система, реально.
大片的英文!望而却步!!
Alguem sabe onde posso baixar softwares .deb
https://www.ubuntuupdates.org/
