Bash快捷键速查 (双语对照) |
Ctrl-a |
Move to the start of the line. 移动到行首 |
Ctrl-e |
Move to the end of the line. 移动到行尾 |
Ctrl-b |
Move back one character. 向前移动一个字符 |
Alt-b |
Move back one word. 向前移动一个单词 |
Ctrl-f |
Move forward one character. 向后移动一个字符 |
Alt-f |
Move forward one word. 向后移动一个单词 |
Ctrl-] x |
Where x is any character, moves the cursor forward to the next “x”代表任意字符,向后移动光标至下一次字符“x”出现的地方 |
Alt-Ctrl-] x |
Where x is any character, moves the cursor backwards to the “x”代表任意字符,向后移动光标至上一次字符“x”出现的地方 |
Ctrl-u |
Delete from the cursor to the beginning of the line. 删除自光标前一字符至行首的字符 |
Ctrl-k |
Delete from the cursor to the end of the line. 删除自光标所在字符至行尾的字符 |
Ctrl-w |
Delete from the cursor to the start of the word. 删除自光标前一字符至该单词开头的字符 |
Ctrl-y |
Pastes text from the clipboard. 从剪切版粘贴文本 |
Ctrl-l |
Clear the screen leaving the current line at the top of the screen. 清屏,使当前行位于屏幕最顶端 |
Ctrl-x Ctrl-u |
Undo the last changes. Ctrl-_ does the same 撤消前一次变更,Ctrl+_与之相同。 |
Alt-r |
Undo all changes to the line. 撤消此前对该行的所有变更 |
Alt-Ctrl-e |
Expand command line. 展开某一命令 |
Ctrl-r |
Incremental reverse search of history. 增量反向搜索历史 |
Alt-p |
Non-incremental reverse search of history. 非增量反向搜索历史 |
Execute last command in history 执行上一条历史命令 |
!abc |
Execute last command in history beginning with abc 执行最近一条以abc开头的历史命令 |
!abc:p |
Print last command in history beginning with abc 显示最近一条以abc开头的历史命令 |
!n |
Execute nth command in history 执行第n条历史命令 |
Last argument of last command 前一次命令的参数 |
First argument of last command 前一次命令的第一个参数 |
^abc^xyz |
Replace first occurrence of abc with xyz in last command and execute it 替换前一次命令中字符“abc”出现的第一处为“xyz”并执行 |
这个很重要哈哈。。
